디자인팜 새로 만든 맞춤 게시판을 메인화면에 넣고 싶은데요!!
- &**bsp;gaji5
- 2015-04-29 18:46:41
- hit4857
- http://lab.anybuild.co.kr/bbs/qna/4384
확인 가능한 전체 URL : http://gaji5.home-dream.co.kr/main
http://rkwldhs.home-dream.co.kr/myboard/gallery1_1 사이트에서 맞춤게시판의 리스트, 일기화면, 쓰기부분의 소스를 복사해서
http://gaji5.home-dream.co.kr/myboard/sample 맞춤 게시판을 만들었어요!!
이 맞춤게시판을 메인화면에 넣고 싶은데 좌측 컨텐츠에는 새로 생성한 맞춤게시판을 꺼낼 수는 없더라구요!
그래서 맞춤형페이지 > 맞춤형 컨텐츠를 꺼내서 맞춤게시판 리스트화면 소스
$totalItem = count($myboard_mylist_row);
<load target="/img_up/shop_pds/rkwldhs/design/tpl/media/magicalLayouts.css">
<load target="http://ajax.googleapis.com/ajax/libs/jquery/1.11.1/jquery.min.js">
<load target="/img_up/shop_pds/rkwldhs/design/isotope.pkgd.min.js">
<load target="/img_up/shop_pds/rkwldhs/design/imagesloaded.pkgd.min.js">
<load target="/img_up/shop_pds/rkwldhs/design/tpl/media/magicalLayouts.js">
<section class="MagicalLayouts">
<!--@if(count($myboard_category_row))-->
<!-- Categories -->
<nav class="categories" id="isotopeCategory">
<ul>
<li data-filter="*">
<a href="{$_SERVER[PHP_SELF]}?myboard_code={$_GET[myboard_code]}">모두</a>
<!--@foreach($myboard_category_row as $k=>$v)-->
<li class="on"|cond="$v[category_idx]==$_GET[category_idx]" data-filter=".{$v[subject]}">
<a href="{$v[url]}">{$v[subject]}</a>
</nav>
<!-- // Categories -->
<!--@if($myboard_mylist_row)-->
<!-- Index -->
<div class="index">
<div class="wrap" id="isotopeContents">
<!--@foreach($myboard_mylist_row as $k=>$v)-->
<div class="item {$v[category_subject]}" cond="$v[view_yn]">
<a href="{$v[read_url]}">
<span class="thumbnail" cond="$v[s_v2_url]">
$img_url = thum_img("$v[s_v2_url]","320","320",0);
<img src="{$img_url}" alt="{$v[s_v1]}">
</span>
<span class="body">
<span class="subject">{$v[s_v1]}</span>
</span>
</a>
<!-- // Index -->
<!--@else-->
<div class="index">
<div class="empty">데이터가 없습니다.</div>
<div class="paginate">
{PAGE_BLOCK}
<!-- <nav class="btngroup">
<a href="{$write_url}">등록</a>
</nav> -->
</section>
<script type="text/javascript" defer="defer">
jQuery(function($){
autoSize();
$(window).on('resize', function(){
autoSize();
function autoSize(){
var magicalW = $("#isotopeContents").width();
if($("#isotopeContents").width() < 650){
var autoWidth = magicalW / 2;
$(".index .item a").css("width", autoWidth);
var thumbW = $(".index .item a .thumbnail").width();
$(".index .item a .body").css("width", thumbW);
else {
var autoWidth = magicalW / 3;
</script>
를 삽입해서 맞춤 컨텐츠를 만들었어요!!
근데!!
분명!! 등록한 3개의 데이터가 있는데
메인에 데이터가 없습니다 라고 뜨고 있거든요!!
메인화면에도 등록한 데이터가 나오게 하려면 어떡해 해야할까요~?!
위의 소스로는 절대로 맞춤게시판의 내역을 가지고 오지 못합니다.
소스만 보면 $myboard_mylist_row 라는게 정의가 되어있지 않기 때문에 어떠한 정보도 출력이 되지 않습니다.
메인에 맞춤게시판 정보를 출력을 할려면 프로글매샵에서 맞춤게시판을 가지고 와야 됩니다.
디자인 팜에서 프로그램 마법사에 더보기를 클릭을 하면 팝업이 뜨는데요..
여기서 맞춤게시판을 선택을 해서 원하시는 형태를 설치를 하시고 그것을 원하는 위치에 넣어주셔야 됩니다.
